Posted by gene bender on February 13, 2010 at 15:51:26 from (207.177.56.220):
In Reply to: 1950 Cub,lights posted by Dougct on February 13, 2010 at 15:41:06:
Check the voltage at the lite terminal then with the lites on use a jumper from the ground on the batt to a good ground on the lite. If the lite gets btighter when you have the jumper wire to ground you have found the problem. The conections can sure get rusty and change the lites after 50yrs.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
