Re: Boosting coil voltage during starting
Posted by The tractor vet on February 16, 2010 at 07:36:59 from (75.19.124.251):
In Reply to: Boosting coil voltage during starting posted by mkirsch on February 16, 2010 at 06:30:00:
With out knowing what coil you have and whatn resistor your using and how long it takes that resistor to warm up to start dropping the voltage to the coil i am shooting in the dark here . When i do a 6 to 12 change over i use a 6 volt coild usually the stock coil and add a resistor off a older Chrysler product and it takes a bit for the voltage to drop off down to around 6-8 volts . Your feed wire to the resistor should be nothing less then a 14. ga. wire from the push pull ing. switch and you sould have at least a 10 Ga. wire supplying juice from the started pole from the battery to the dash . . JT's has a couple good ideas also .
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
