Posted by Andrew Z on March 01, 2010 at 08:00:19 from (64.252.41.103):
In Reply to: Re: 1943 H X3 posted by primerk5 on March 01, 2010 at 07:35:23:
There would have been two tanks a small 7/8 gallon starter tank in front of the main tank. A special fuel bowl that is designed for 2 tank input. Other things would have included a different manifold, it would have had a heat shield and heat control valve. The head would have been different when compared to a gas mainly larger combustion chamber to burn the low grade fuel, valves are slightly different too. There would have also been a radiator shutter to get it up to temp quicker and control heat. The carb was also slightly different when compared to a gas burning engine. Other then that they are about the same as a gas. main things were the head and manifold.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
