There are two big cast iron bushings. I had the same issue with my F12. Instead of trying to search for good ones, I fixed the originals. If you are good with a welder and a lathe you can do that yourself or take them to a machine shop. On mine I also had to weld up the axle shaft and turn it true again in a lathe. Than I used the lathe to drill/reem out the center of the two busihngs so they were true again, than pressed a brass bushing into each, to fill the new gap, and so that they would wear rather than the cast pieces. After that I just sized the bushings for the new axle diameter, put it back together and its good as new.
Hope this helps you
-Jordan
This post was edited by J.J. from Afton at 17:38:32 03/05/10.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
