I don't know if a similar reply was in the original thread. Your C has wet sleeves. You can pull the pan, and look at the cylinders from the underside. If you see water coming from between the sleeve and the block, green or otherwise, the cylinder sleeve rings are leaking. One of my C's is also leaking, have not had time to fix it yet. Otherwise, change the oil and anitfreeze. Run it a while, let it set long enough for the antifreeze to settle to the bottom, open the drain plug enough to make it drip -- you will see the antifreeze, particularly if green, if it is leaking from anywhere.
Today's Featured Article - Usin Your Implements: Bucket Loader - by Curtis Von Fange. Introduction: Dad was raised during the depression years of the thirties. As a kid he worked part time on a farm in Kansas doing many of the manual chores. Some of the more successful farmers of that day had a new time saving device called a tractor. It increased the farm productivity and, in general, made life easier because more work could be done with this 'mechanical beast'. My dad dreamed that some day he would have his own tractor with every implement he could get. When he rea
... [Read Article]
Latest Ad:
[More Ads]
