The tool is a flat bar with a couple of curves in it. It is used to release the lock pin for the over center clutch adjustment.
The adjustment is for the clutch, not the brake. If the clutch does not slip and is fairly hard to engage, most likely the adjustment is OK. The brake is spring applied. If the brake lining is not worn out a common problem is the snap ring off the front end of the shaft.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
