Re: How do you tell a 6 volt coil from a 12?
Posted by primerk5 on March 07, 2010 at 05:00:25 from (72.85.32.233):
In Reply to: How do you tell a 6 volt coil from a 12? posted by mkirsch on March 06, 2010 at 17:41:21:
John T said: (quoted from post at 19:26:07 03/06/10)
ANSWER: Many original coils designed for use at 6 volts have a primary winding resistance as measured between their small + and - terminals around 1.25 to under 2 ohms (1.5 ohms typical)......THEY ARE LABELED 6 VOLTS
Thanks John, This is excactly what I was looking for.
There wasn't a battery on the tractor when I got it. I've basically been using my 12 volt lawn mower battery to hear it run. The wiring on the tractor is mostly original, missing its loom, and very ratty/broken up. The one and only battery cable that should have been connected from the starter button to the starter was only connected to the starter and was almost completly bare of its insulation.
The center post on the regulator is unhooked and I think thats the supposed to be the charging wire back to the amp meter.The wire was still there and hanging but has been disconnected from the amp meter as well. I tried connecting it to the terminals to see if anything would happen but I didnt get anything to register on the amp meter. May not be charging or it could be to much rust on the contact of the regulator. I havn't cleaned them yet.
The regulator is pretty rusty. I've seen where it has ink marking underneath the regulator that says 12v or 6v on aftermarket ones. I was wondering if IH put it on the OEM ones or not. I'll have to take a look at this.
Basically I would like to know what the charging system should be so that I can get a battery for it in the future. I figure I'll leave it the way it is, 12v or 6v, whatever it is.
I'm going to have to check out the generator for that tag today. Hopefully there is some paint left to it. It seems some one installed an upper mount off a car so that the alternator would swing further to tighten up the belt instead of tighting up the pulley. The hood hits against the mount and won't fully close.
Thanks for the wiring diagrams Jim, these will help and keep me from having to take other H part to see where the wires are supposed to run.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
