To install the end for the distributor, trim the lead so that the wire extends about 1/4" past the insulation. Put the wire through the hole of the terminal end and fan out the end of wire. Push the lead into the terminal on the cap to bend the sides to the proper dimension.
That will leave you with a wire that fits snugly into the cap and the conductor wire will be in contact with the terminal in the cap.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
