Posted by Two Banger on March 11, 2010 at 14:11:36 from (205.188.116.19):
In Reply to: Kill Switch posted by jim from az on March 10, 2010 at 18:32:28:
I guess I sent out a little bit of confusion with this one. Sflem849 hit it just right. This is not an ignition switch. It mounts to the back of the tractor to hook a cable to while competing in tractor pulls. In the normal state (pin in) there is no circuit made, if a break a way occurs (pin pulled out) it makes the circuit. I agree one that works the opposite would be a lot easier to wire. Unfortunately all break a way switches that I have found work like this one. Will I hurt anything if I ground out the coil? Seems like to me a dead short across the coil would not be a good thing. A magneto is a completely different animal though.
Today's Featured Article - Oliver 550 Clutch Overhaul Tips - by Greg Sheppard. I got my 1964 Oliver Model 550 (serial 141-139-519) second-hand and used it for several years before the clutch began to slip. After taking up the pedal linkage several times I saw it was going to take more than that. The engine had been leaking oil at the rear seal and I suspected
... [Read Article]
Latest Ad:
[More Ads]
