Re: Farmall H able to pull what size stalk chopper?
Posted by riverbend on March 12, 2010 at 06:00:10 from (74.46.187.214):
In Reply to: Farmall H able to pull what size stalk chopper? posted by ryanwheelock on March 11, 2010 at 06:04:39:
I have a similar 10' disc. I use it with my H and it works fine on our light soil.
Check the bearings and carriers carefully. The carriers in the front wear out from dragging in the dirt and are about $125 a piece. The bearings are about $65 each, seals $7 a piece. By the way, there are two different carriers depending if the disk is early or late. Mixing them will blow up the bearings.
Greg
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
