Farmall Tractors Discussion Board
Post Hole Digger
Posted by Matt on December 31, 1998 at 13:49:25:
Last year I picked up an older style post hole digger. It's not a 3-point hitch style and the owner believed it came off of an old
Farmall of some type. The paint or whats left of it is IH red. There are two metal ID tags on it. One says "Danuser Digger" and the other "Dearborn Mfg., Tractor and Implement Div., Ford Motor Co., Model 22-59". What I would like to know is what tractor this could attach to and how this digger attaches to a tractor. It has two main lift arms (pipe about 5' long) which have perpendicular bushings welded to oneend as though to fit over a 7/8 pin. About 2' down from the open end are two plates welded to the pipe. The plates are set
about 1 1/2" apart and have holes for a 3/4 pin (obviously a lifting point). On top of the main lift arms slip 2 larger diameter pipes about 2' long. These pipes are connected to the auger head. These pipes also have connected to them 4'long 1" diameter pipes which look as though they attach back to the tractor somehere. Any help would be greatly appreciated.
Post a Followup
: Re: Post Hole Digger
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
