Ron, here's a repost of a post I made farther down the page.
If you can measure the primary current as explained below it will show if you have the correct resistor.
"Here's the straight FACTS.
Coils vary in primary resistance depending upon part number, manufacturer and application. Some are as low as 0.5 Ohms, some close to 5 Ohms.
For acceptable breaker point life at a specific system voltage the combination of coil primary resistance and any added external resistance must be such that primary current (ignition "on", points CLOSED, engine stopped) is in the 3 Amp to a maximum of 4 Amps (give or take a little) range.
Less than 3 Amps will PROBABLY give a weak spark, much over 4 Amps will be tough on breaker points.
If you can, when you get your new resistor installed, MEASURE the actual primary current and see where you're at compared to that range.
NOTE... besides different resistance VALUES, ignition resistors may be either fixed resistance or "PTC" (positive temperature coefficient).
With FACTORY systems, generally a FIXED resistance is used with systems that have a "starting bypass" (a separate terminal on the starter switch or solenoid that provides full battery voltage to the coil during cranking).
For FACTORY systems NOT using a "starting bypass", a PTC "ballast resistor" is used. When the ignition is switched "on" the resistor has a relatively low resistance to aid in starting, then it's resistance quickly drops to a higher value as it heats up to prolong point life and cause less heating of the coil.
NAPA, Standard Ignition, BW, etc., have parts guides that will show the resistance for a given part number and whether it's fixed or PTC.
Finding a counterman who is willing to grab that guide and have a look is another matter.
Also, there's "true" 12 Volt coils on the market that have enough primary windings so that no external resistor is needed. NAPA IC-14SB is ONE example of such a coil."
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
