No split required. Pull pump out if equipped. Remove clutch shaft and related parts. Photo the coupler and be patient. Loosening the clutch disk, or putting three of the clutch cover bolts (from 120 degrees apart) into holes near the levers to compress the clutch. and holding your mouth just right will allow the shaft to come out. Then pull the flange off. a puller, or using the shaft yolk as a puller against the shaft with a socket to push on (center bolt removed) will get the drive yolk off, then just pry out the old seal. Check for a groove in the yolk, and if it is easily felt, I would speedy sleeve it, or run the new seal in a different depth to provide a good seal. Jim
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
