Posted by Cub149 on April 11, 2010 at 12:16:39 from (98.17.210.230):
In Reply to: 350U Axle Seal posted by Andy Martin on April 11, 2010 at 11:13:01:
Max(ia) said: (quoted from post at 19:13:01 04/11/10) Rear axle seal leaking. Is this a major project to replace? Also, what fluids are used in Trans. and Rear End. Thanks
If you have a T/A, you should use Hy-Tran or equivilent. If not, 80w90 gear lube is a substitute. You need to take off the wheel, then remove the center bolt from the hub. The hub is splined to the axle and needs to be pulled off. Then the four bolts on the bearing retainer where you will find the seal. Also need the O-ring type gasket to seal the splines and either gasket or silicone for the bearing retainer.
Today's Featured Article - A Brief History of Tractors in Australia - by Bob Kavanagh. After Captain Cook's exploration of the east coast in 1770 the British Government decided to establish a penal colony in Australia. The first fleet arrived in 1788 and consisted mainly of convicts who were poorly equipped and new little of farming techniques. The colony remained far from self-supporting and it was not until the early 1800's that things started to improve. Free settlers started to arrive, they followed the explorers across the mountains and where land was suitable set up farms. T
... [Read Article]
Latest Ad:
[More Ads]
