Re: Touch Control problems - calling CNKS
Posted by mkirsch on April 15, 2010 at 05:14:50 from (64.80.108.57):
In Reply to: Touch Control problems - calling CNKS posted by couv on April 15, 2010 at 04:59:32:
CKNS is on here frequently, and he certainly saw your other post on this exact same issue... If he had anything helpful he would've posted. However he's as stymied about your problem as the rest of us, I'm sure.
There is a complete Touch Control service manual online at wwwDOTcleancomputesDOTcom/Cub. It covers both the Super A style and the Cub style Touch Control systems, and may have your exact problem right in the troubleshooting part.
While I can't help you on the mechanics of the problem, I can tell you that the color of the fluid has nothing to do with it. People often check/change the oil as the first troubleshooting step, when it really doesn't make any difference.
If the oil is the cause of the problem you would see much more obvious symptoms. You would hear very strange noises as gears grind themselves to dust. You would hear screeching as bearings siezed. You would find metal shavings. You may go so far as to find inside parts sticking through the case of the machine to the outside.
Nope, if the oil is wet and slippery, it's still doing its job. Maybe not as well as it would if it were new, but well enough that things aren't blowing up on you.
No matter what you do, the oil will start to darken almost immediately in whatever you put it in. If you didn't empty and clean the lines and the pump, that's where your discoloration is coming from. Not a big deal.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
