Re: Help !!
Posted by Jg20601 on April 16, 2010 at 19:55:40 from (65.55.67.224):
In Reply to: Help !! posted by nk on April 16, 2010 at 18:36:39:
I would drain the system of the fuel/sugar mix and wash everything out good with water. Either replace the fuel bowl/filter or clean that up good as well.
If it had been run with sugar in the gas tank, I would clean the fuel lines and drain the carb as well, letting some new fuel fun thru the carb to wash out the bowl.
Hopefully that would do it - but dont forget to look for other monkey tricks - like switching plug wires.... after all if they put sugar in the tank....
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
