Posted by toro in texas on April 23, 2010 at 23:07:39 from (67.216.252.175):
In Reply to: timing a 504 farmall posted by skye farm on April 23, 2010 at 04:02:13:
My manual says 22 degrees for engine numbers prior to 4484, 20 degrees for engines numbered 4484 and up. 25 degrees for C153 LP gas engines.
Also heads up incase you didn't know...if you happen to have low oil pressure the C153's oil pump's bottom plate is prone to warping, leaking, and loss of pressure. It's a pretty easy fix and discussed in these archives. Good luck
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
