Posted by Rootsy on April 26, 2010 at 08:56:13 from (24.247.111.162):
In Reply to: Steering help posted by Janicholson on April 26, 2010 at 06:24:39:
The pitman arm has to come off before the lower half of the casting can come off... Need to remove the front axle also... It is often easier to support the tractor under the bellhousing on a jack stand and pull the whole front end off.
Once the steering shaft is out, the axle off and the pitman arm off you can unbolt it and work it apart. There are 2 locating dowels.
Once in there there isn't much. The bushing in the casting you removed... Sector gear is keyed to the shaft and has a bearing on it which is held in the upper casting by a retainer held in place with 3 bolts.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
