Posted by rdfarms on May 13, 2010 at 16:20:29 from (70.100.7.126):
In Reply to: CRANKSHAFT PULLEY posted by mathew koetting on May 13, 2010 at 15:34:52:
just got done pulling the crank pully on my sc. i borrowed a split bearing tool and a big puller from a good friend. it took a big pipe on a half inch breaker bar. thought something was going to break. it would not budge until we rapped on the end of the puller with a big hammer. then it moved a hair. we had to repeat this till it was almost off before it startedto move easily.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
