Re: C135 Engine Swap
Posted by MisterT on May 18, 2010 at 11:25:57 from (209.152.78.140):
In Reply to: C135 Engine Swap posted by farmer_adam on May 18, 2010 at 11:14:13:
Eric P said: (quoted from post at 19:14:13 05/18/10) I have a Super C with a bad motor, yes 15+ years outside does bad things here in Iowa. I have heard you can put a 135 or even a 153 engine from a combine or such as a replacement? Any words of advice or stick with tring to find another 123? Yu guys are the best!
Define "bad motor". If the block is NOT cracked, you would probably be better off to rebuild what you now have.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
