Engine on H stopped turning.
Posted by marvin on May 30, 2000 at 11:05:24 from (134.134.248.22):
My son finished restoring (repainting) his grandfathers H complete with new stickers and the whole bit. It looks very nice. We reinstalled the magneto and timed it properly. We then pull the carb apart and fixed the needle valve so that we could get gas to the engine. We then started it and ran reasonably well. It did not seem to be quite as smooth as I thought it should be. This engine had been stuck when we got it, after getting it loose we measured 90, 60, 30 and 90 PSI from #1 to #4. So we had it running on Friday night and then on Saturday and Sunday. Yesterday (Monday) as my Son started it up, it fired quickly and came to life for about 5 seconds and then died like it ran out of gas. He tried to crank it over again and it would not budge. We tried to crank it over using the fan (switch was off) like we did when setting the timing, and it still would not budge. Like the engine was froze solid. Towed it up to the garage and started to pull parts off. 1) Pulled the starter-starter would spin by itself, but engine still stuck. 2) Pulled magneto- magneto free- engine still stuck 3) Pulled valve cover- all valves still in spring clips and would still depress using a screw driver. 4) Pulled the pan and everything was still in one pieces 5) There was no knocking noise prior to the engine not truning anymore 6) Pulled rod caps on #1 and #4 -Could now move crank via fan about 1 inch back and forth 7) Pulled the head- All the valves looked nearly new and seated properly 8)Used Hammer and piece of wood to tap out #1 and #4 pistons - Did not want to move up very well 9) Tried to tap them down from the top and got some movement. 10) Then grabbed the fan blades and rotate the engine over with ease pushing #1 and #4 to top(This was a surprise) 11) pulled all four pistons out and they looked absoulutely fine. Rings were all intact and loose. Not much wear on pistons. Sleeve looked fine 12) All of the journals on crank look fine. The bearings show very little wear if any. 13) Had tractor out of gear while trying to turn it over. Even depressed clutch to see if that made a difference. 14) I did not pull the timing cover on the front of the engine to see if anything was damaged there. 15)I do not have a micrometer to check the bearings or the piston slop, but there were no ridges at the top or bottom of the sleeves and the pistons were tight in the bore. What could have kept the engine from turning over?
Home
| Forums
Today's Featured Article -
An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
