Re: Click sound 560 axle/brake area
Posted by MN Scott on May 24, 2010 at 06:43:18 from (12.157.197.253):
In Reply to: Click sound 560 axle/brake area posted by matthies on May 23, 2010 at 09:14:37:
When you had the cover off did you check the condition of all the teeth on the gears? A chipped tooth can cause a tick. Maybe something laying in the bottom of the transmission that the bull gear is hitting? Make sure the bull pinion bearings are tight with no damage. Double check all wheel and hub bolts, a hub casting or axle shaft can be worn a bit and even with super tight bolts there can be enough movement to cause a noise. The clamp type castings are known for this on 560's.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
