Posted by John T on June 01, 2010 at 05:37:27 from (66.244.97.31):
In Reply to: changing to 12 volt posted by Jeremy Kamradt on June 01, 2010 at 04:52:47:
QUESTION: What changes need to be made to the original generator to switch to 12 volt?
I have used a 6 volt genny and made it charge a 12 volt battery simply by using a 12 volt voltage regulator and it worked but didnt charge at any real high rate BUTTTTTTTTTTTT THATS NOTTTTTTTTTTTTT THE ENGINEERING "CORRECT" ANSWER as the fields could possibly overheat????
QUESTION Can I put a 12 Volt regulator and battery on and it would work? SEE THE ABOVE
The best method is to use a 12 volt generator
ORRRRRRR Have a genny shop convert your 6 volt genny to a 12 volt
ORRRRRRRRR use an alternator (most require Neg ground remember which requires the coil leads and ammeter leads be swapped)
As far as the ignition coil you can EITHER keep the existign 6 volt plus add an external series voltage dropping (12 to 6) Ballast resistor or else get a new 12 volt coil no ballast required.
The 6 volt starter can still work at 12 volts but it can be a bit tough on starter drives.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
