Super C leaking Hydraulic fluid into motor
Posted by Dean Olson on June 04, 2010 at 17:00:14 from (76.31.47.68):
I got the pump apart and everything looks good No obvious groove in the pump shaft, no cut orings etc. All other parts look good. This pump was/is working good and very strong. The pump will lift a 7' fast hitch disc off of the ground with little effort. The question is: Can I get by with just replacing the shaft seal? The shaft has no perceptible groove or reduction in diameter. I will get it mic'ed and see what that tells me.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
