Re: Need help disassembling a hydraulic Cylinder
Posted by IH fan on June 09, 2010 at 19:49:21 from (208.189.39.25):
In Reply to: Need help disassembling a hydraulic Cylinder posted by Justin-PA on June 08, 2010 at 18:27:38:
I'd take a big hammer and heavy brass or aluminum rod (1" dia. or so) as a drift and drive the end cap in a little like has been suggested and the ring should come out fairly easily. Then using the piston as a battering ram from the inside to pop the end cap out. Helps to have a heavy bench and vice.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
