Re: 460 injecter issue
Posted by sflem849 on June 10, 2010 at 10:03:45 from (69.197.84.192):
In Reply to: 460 injecter issue posted by Richard Hoewisch on June 08, 2010 at 18:25:05:
third party image
third party image
This isn't the tool that got the precups out in the end. I built a heavier plate with a 1/2" nut welded to it and used a very large slide hammer.
If your injectors are not 2 piece injectors this might not work out for you, but it might give you an idea on where to head.
Today's Featured Article - Engine Valves - Some Helpful Information - by Staff. Intake - On the intake stroke the piston moves doward, sucking in carburized fuel through the open intake valve. Exhaust valve is closed. Compression - With both the intake and exhaust valves closed, the pistons upward stroke compresses or squeezes the fuel into the combustion chamber. Firing - Ignited by the spark, the compressed fuel explodes and forces the piston downward on its power stroke. Intake and exhaust valves are closed. Exhaust valves and seats are exp ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
