Finally an answer International 300 Utility
Posted by Chas Weller on June 13, 2010 at 19:29:57 from (71.241.107.109):
It has been several weeks - tractor would not
start - firing out exhaust and intake " timing
problems " Exactly ! had to remove loader, remove
front end plus the normal items to access the
front cover of the motor. Well the nut came off
the cam (must have been off for awhile the nut is
in perfect condition)the cam gear finally wore all
the threads off the cam, the keyway became loose
enough and the gear wore the teeth off itself and
the distributor drive gear. Remember when the
valve cover was removed all the valves still
operated and correctly. Well now I need to find a
camshaft, cam drive gear with key, distributor
drive gear plus the oil slinger for the front of
the crankshaft; also a manifold(found badly
cracked). As always thanks for the help, advice
and shared years of knowledge and experience! Any
suggestions as to the best source for parts?
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction, ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
