Re: electrical drain on H ?
Posted by Brownie 450 on June 16, 2010 at 17:46:34 from (66.43.241.95):
In Reply to: electrical drain on H ? posted by riverbend on June 16, 2010 at 16:15:29:
If your meter has ohms scale--RX1--unhook the neg cable from the battery & measure resistance between neg cable & ground [tractor frame]. What resistance is present? If resistance is less than 100 ohms, start unhooking wires 1 at a time from the ammeter until the reading is near infinity [high resistance]. Bear in mind that the starter switch may be causing some trouble here, so check that out also. Look for bare or garfed wires/ insulation bad. Could also disconnect wires 1 at a time from the regulator to isolate a problem there.
Today's Featured Article - The River Tractor - by Charlie English Jr.. This is a 4010 John Deere that was used to farm on the Diamond Island which is in the Ohio River about 15 miles southwest of Evansville, Indiana. About ten years ago, this tractor was parked close to the bank as the river was washing the bank of the island away. ... [Read Article]
Latest Ad: 1945 Farmall wide body gas with pto and front plow. Runs good but needs new points. [More Ads]
