Posted by Wardner on June 17, 2010 at 06:19:58 from (4.154.238.138):
In Reply to: w6 rear axle spline posted by farmall paul on June 17, 2010 at 01:26:01:
There are epoxy keyway repair products.
I am guessing that a satisfactory repair would involve injection under high pressure. A clean grease gun would be one source of the pressure. You will probably have to throw the grease gun away after use.
Seems like you would have to drill and tap 6 or 12 holes in the wheel to insert to grease fittings. Or perhaps you could make an adaptor to fit over the end of the axle. It would have to be machined and leak free with a seal. O-ring would be easiest. A mold release or wax would have to be applied to those areas where the excess epoxy needs to be removed.
I can't see that backyard welding and fileing would ever be satisfactory. A machine shop could do it but it would be cheaper to import a used wheel and or axle from the US. That axle was probably used through the 560 standard tread tractors. Not sure about the wheel but there were probably several different wheels.
This post was edited by Wardner at 06:36:18 06/17/10 2 times.
Today's Featured Article - Talk of the Town: The Saga of Grandpa's Tractor - by The following saga is from the Tractor Talk Discussion Forum. Someone. The saga starts with the following message: Hey guys I have a decision to make. I know what you all will probably suggest and it will probably agree with me way down inside, but here it is. I have a picture blown up and framed in my "tractor room" of a Farmall M. It was my Grandpa's tractor, of which whom I never got to meet. He froze to death getting this tractor out of the barn to pull a truck out of the ditch before I was born. Anyway my dad and aunt had to sell it at the auction,
... [Read Article]
