The torque amplifier (lever on left) is to change speed on the go, without using the clutch, to compensate for a heavier load. If you are pulling a tillage implement that starts to lug the tractor down, snap that lever back and it shifts to a lower speed for more lugging power. You can also use it on other implements, baler, swather, etc. if you get into a heavier load situation. Do not move that lever slowly... if you are going to shift, snap it in and out quickly. Do not use the TA to slow the tractor down for braking.... it "free-wheels" in low TA, for example slowing it going downhill with a wagon load behind you... it will push you faster.
This post was edited by IH fan at 02:19:54 06/18/10.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
