Your problem is that the springs on the shift detents are broken. There's a cam mechanism in the transmission that holds the tractor in gear, which uses a spring to hold the gear shift in place. If the gear lever "floats" and doesn't "snap" into place, that is your problem.
This requires removing the platform and pulling the range cover, which is located about where you keep your feet. It's not a huge job but if you're not mechanically inclined, you may want to seek local assistance.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
