i think they got you pointed in the right direction. Your shifting is hard because your dump valve for your TA is problay out of adjustment. It's located on the valve block where you got to set on. When you push your clutch in it should pull this valve. you need set it where your ta just dumps after the main clutch does.
Put you tractor on a slight slope, push the clutch it. It will only roll backwards when you push the clutch far enough to dump the TA, You need to adjust it till it will engage the dump valve sooner until it rolls back but not too soon. Because you will be engage the TA before the main clutch.
It's something you need to know to but almost need a lesson by someone.
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
