Re: *Super M Again*
Posted by Janicholson on July 01, 2010 at 09:00:31 from (199.17.6.23):
In Reply to: *Super M Again* posted by gatorhide on June 30, 2010 at 16:46:21:
Put it together except the distributor cap and rotor.
Put the coil wire (cap end) near the block and tape it so it stays near the block 1/8" will do)
use a plastic handled small screw driver to touch the rubbig block of the points, weaseling them open. If you get a spark, and the points are gapped when the cam has them max open, it should run. If no spark, the points are grounded or the condenser is shorted, or the stack of washers and insulators is shorted to the distributor housing. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
