I have not had much experience working on a 560 however I do know quite a bit about mechanical engine operation and theory and have never seen nor heard of an engine stalling from pre-ignition (unless it caused a failure of some sort)... Try not to over think the problem right out of the box. Start with the least intrusive diagnosis first and work you way up from there. I would have started off the same way you did with the tune up, plugs, wires, cap, rotor, coil, condenser. After that like the vet said look at you fuel flow. A quick check to see if it may be a fuel or air problem pull the choke out when the engine is in the process of stalling. If the RPM's come back up that's most likely where you problem lies. From there I would start looking at the carb, maybe a good carb kit, cleaning and adjustment. Check the govenor for proper operation and adjustment. After that I would look into the base engine, compression, valve springs, etc. Good luck! Matt
Today's Featured Article - Listening to Your Tractor - by Curtis Von Fange. Years ago there was a TV show about a talking car. Unless you are from another planet, physically or otherwise, I don’t think our internal combustion buddies will talk and tell us their problems. But, on the other hand, there is a secret language that our mechanical companions readily do speak. It is an interesting form of communication that involves all the senses of the listener. In this series we are going to investigate and learn the basic rudimentary skills of understanding this lingo.
... [Read Article]
Latest Ad:
[More Ads]
