Re: Farmall 706 turns over but won't start
Posted by rvirgil_KS on July 30, 2010 at 14:18:17 from (204.120.15.207):
In Reply to: Farmall 706 turns over but won't start posted by R. Matchock on July 30, 2010 at 10:22:09:
Check the ignition coil resistor. If it is open the engine will start when the starter is cranking but will die when start solenoid releases.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
