Posted by Owen Aaland on August 07, 2010 at 06:31:23 from (65.165.246.191):
In Reply to: 706 torque question posted by clattermac on August 05, 2010 at 13:35:24:
Since the steering is good the first thing I would check is the power brake valve. There is an orifice under the inlet line fitting to restrict the oil flow to one GPM. The 706 uses an open center brake valve so if that orifice comes out it can dump too much oil through the valve and cause loss of pressure in the TA system. Try shifting the TA while applying the brakes. If that improves the shifting the orifice may have come out. Remove the line and fitting to get access to the orifice.
Problems in the MCV assembly may be a blown gasket, broken spring on the pressure regulator valve, or a stuck regulator valve. The TA may also have too much leakage, usually worn sealing rings and bushing on the input shaft.
With the open center power brake valve you only have two GPM available to the TA. Later tractors used a closed center valve so they have three GPM available.
Today's Featured Article - An Old-Time Tractor Demonstration - by Kim Pratt. Sam was born in rural Kansas in 1926. His dad was a hard-working farmer and the children worked hard everyday to help ends meet. In the rural area he grew up in, the highlight of the week was Saturday when many people took a break from their work to go to town. It was on one such Saturday in the early 1940's when Sam was 16 years old that he ended up in Dennison, Kansas to watch a demonstration of a new tractor being put on by a local dealer. It was an Allis-Chalmers tractor dealership,
... [Read Article]
Latest Ad:
[More Ads]
