Posted by Tyler Jackson on August 10, 2010 at 15:42:52 from (75.207.61.162):
This could be a long explanation. last week starting the H we were putting it on tdc i leaned over from the other side and put my hand on the generator and it was really hot. so we took it off thinking something was wrong and later got her started. I took the gen in to get it tested and the guy said it was fine so I figured it was my rewiring job. got a diagram off here and rewired it to the diagram but i noticed on the amp guage it showed a charge when it wasn't running and it didn't have the gen on. soo i wired it back to original and it was still doing the same thing when the lights are on when not running. havn't put the gen back on but i guess my question is what would make it say its charging and make the gen hot???(we had only cranked the engine over like 5 times when it got hot) very much appreciative for the help
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
