It looks like an A to me. Look to see if there is a plate hidden under all that grease on the right-hand front corner of the block where the Hydraulic pump would go. There is definitely no hydraulic pump on it now. It would go below the Governor/Distributor drive and be driven off the Cam/Governor/Distributor gear train.
Also look at the top of the torque tube, under the gas tank for a flat spot with mounting holes. That is where the touch control would go.
If there is no plate covering where the hydraulic pump would go, and no place to mount the touch control, it is a Farmall A, not a super.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
