Re: Starting a 140 after it caught fire............
Posted by AL Farmall Boy on August 18, 2010 at 08:38:49 from (74.248.177.77):
In Reply to: Starting a 140 after it caught fire............ posted by AL Farmall Boy on August 18, 2010 at 08:16:26:
List of NEW Parts (pertaining to engine):
Starter Solenoid
Key Ignition Switch
Coil (with built in resistor)
Set of Plug Wires
Distributor Cap, Rotor Button, Points, Condenser
Radiator Mounting Pads (set of 2)
Oil Pressure Gauge
Water Pump
Thermostat
Radiator Hose (upper)
Radiator Hose (lower)
Spark Plugs (4)
Oil Filter
Fuel Sediment Bowl
Carburetor
Fuel Line (flexible)
Fan Belt
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? " ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
