Re: Farmall 350 Row crop
Posted by Rdandersom on September 11, 2010 at 06:38:33 from (64.235.100.62):
In Reply to: Farmall 350 Row crop posted by Dean Olson on September 07, 2010 at 14:17:52:
I started farming in the 80"s with a 300 with 350 pistons & liners.It was a great old tractor.A set of rear wheel weights make a big difference to its pulling power.I abused the old girl pulling silage wagons through mud and regularly hauled 10 tons of shelled corn plus wagons to the elevator.The 300 was a joy to plant and spray with too.I did all my tillage with a 36 plate Kewanee disc and had no trouble pulling it in the spring on untouched ground.
On the other hand it did burn more fuel than a diesel. The split between first and second gear is a little too wide (had to pick corn in first) and you may have to deal with TAitis at some point.
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
