Re: Working M, won't start, emergency!
Posted by Armand Tatro on September 15, 2010 at 15:26:50 from (71.239.9.235):
In Reply to: Working M, won't start, emergency! posted by Mr77FM on September 15, 2010 at 13:52:24:
Does this tractor have a live hyd. pump driven by the dist. drive. If so you may hav a broken cam/timing gear. To get to the the timing gears you have to remove the front bolster, radiator, crankshaft pully, and front cover. To get to a couple of front cover bolts they come off from the dist/hyd. pump side of the block. You need the front support stand of the splitting stand assy. to safly support the engine half of the tractor. Armand P.s. Let us know what you. find.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
