Re: Farmall H charging system
Posted by John T on September 15, 2010 at 19:53:12 from (66.244.97.31):
In Reply to: Farmall H charging system posted by Chris Sweigert on September 15, 2010 at 17:31:53:
If a good battery ran down in only 15 minutes after you shut her down, I wonder if the Cutout Relay contacts inside the VR stuck closed??? If so right after you shut her down the ammeter would have swung to a heavy - discharge and the genny would get warm. In fact if the belt had been removed it would have spun like the DC Motor it actualy is.
That 13 volt running sounds "decent" as setting the battery voltage would be 12.6 but at fast RPM with a good genny Id expect it to rise to 13.5 or up near 14 depending on the battery state and VR and genny and RPM.
FIRST make sure the Cutout Relay inside the VR isnt stuck closed cuz if so the battery will discharge rapidly and the genny get hot.
Next Id check for a good case ground on the VR and genny itself, maybe try a ground jumper wire (also insure a good tight belt???)
Next Id run Para 5 of my Troubleshooting Procedure where you ground the gennys FLD post to see if she charges then ?? If so but NOT otherwise the VR isnt well grounded or its bad. if she charges fine when you ground the gennys FLD post and the VR has a good ground I SUSPCET THE VR
Check for that stuck cutout relay !!!!!!
Check the belt tension !!!!!!!!!
Check for a good VR ground !!!!!!!
Run my Par 5 grounded FLD test !!!
If none of the above, maybe a VR problem
Take two aspirins n call me at the office
John T
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: 18-32 Case Cross Motor [More Ads]
