Hold your hand over the throat of the carburetor and see if there's good suction. You will need a helper to make an attempt to start the engine. If there's not much suction means you have low intake manifold vacuum that's necessary to draw that fuel into the engine. Check your intake manifold to make sure it is tight and not leaking. I would do a compression check to see what that is and compare the readings. Worn sleeves and valves not seating can cause low intake manifold vacuum. Hal
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want … unless you own a monster tractor. U
... [Read Article]
