If you use the booster pack, or any 12v battery, a simple way to avoid charging system damage is to jump to the ground on one lead (close to the starter, or a starter bolt) and (with it in neutral, brakes set, ignition on) touch the other jump lead to the terminal on the starter motor (polarity does not matter because it is not putting 12v into anything but the starter motor. This will assure no regulator damage. Jim
Today's Featured Article - Oliver 550 Purchaser Checklist - by Greg Sheppard. Pound for pound the 550 is better than anything I've seen. It has great power for its size and can really hunker down and lug. Classified as a 3-bottom plow depending on soil conditions. I personally don't think it can be beat for a utility tractor in the 40 HP range. They are extremely thrifty on fuel, at least my DSL is. Most drive train parts are fairly easy to get. Sheet metal is probably the hardest thing to
... [Read Article]
