The Delco does have advance components. They can be checked (to a limited degree) by gently turning the rotor by hand, in the same direction as rotation, it should turn a few degrees against spring pressure, then when released it should spring back. Rich mixtures almost always are carburation, or air supply. Set the static timing to TDC. and check it with a timing light to assess the advance. Jim
Today's Featured Article - Talk of the Town: Winterizin Engines - To Drain or Not to Drain? - by Staff. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "Winter is fast approaching..for a gas tractor should the gas tank be drained and run the engine til the carb is dry or do the gas stabilizer products I've heard of work? (tractor will not be used til spring) any other tips for winterizing?? "
... [Read Article]
Latest Ad:
[More Ads]
