The next time the problem occurs, note the engine RPM (hopefully you have a tachometer), road speed and the trans gear you are in. Then shift down a gear (say from 5th to 4th) and then maintain the same road speed of the problem. If the issue goes away, then decelerate to the RPM of the issue and see if the problem comes back. This will tell you at least if the problem is associated with engine speed (RPM) or road speed. If engine RPM sensitive, look for something with the engine - if road speed sensitive, look for something in the driveline or (potentially) the running gear (wheel tires, suspension) or the like. Too hard to diagnose otherwise without experiencing the problem first hand or a better description.
Today's Featured Article - Measuring with Calipers - by Staff. The legs of inside calipers are curved outward at the extremities to facilitate measuring small holes, while outside caliper legs have a large curve inward to increase their capacity for large work. Firm-joint calipers are adjusted approximately by the hands and then set to the feel of the work by tapping them on a metal surface. It is a common practice when opening calipers by this means to tap the top of the joint. It is better, if possible, to tap the inside of the legs, as repeated blo
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
