Checking the oil level in the filter cavity will not work. The system is designed to keep that area full of oil no matter what the level is in the rest of the system. The inlet to the filter cavity is above the oil level so it doesn't drain all the oil out when the filter is changed. It also keeps the pumps from drawing in air when the tractor is started.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
