Re: Quick Question about wiring a Cub.....
Posted by gene on November 07, 2010 at 18:35:18 from (66.43.40.73):
In Reply to: Quick Question about wiring a Cub..... posted by RTR on November 07, 2010 at 18:05:03:
Read note #4 at the bottom of the diagram. Diode is easier. And you don't have to worry about where you are going to put the light.
Yes on wiring the light. But you need a bulb of the listed specifications.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water. ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
