I already had a hole in the dash of the Cub to mount the light and thought it would give a nice touch as well as cover the hole. The only light I could find at the AutoParts Store was a generic LED light with a plastic "Chrome" bezel. It was $12 too. I asked for a generic old fashioned warning light and they said that is all they had.
When I turn the key on, the light doesn't come on, but I checked the connections with a tester, and I am getting power to it. Since the light package directions says that one terminal is the ground, should I "ground" one terminal and simply put both wires on the other terminal???
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
