Another thing to do is put a 10 ohm 10 watt ceramic resistor(Radio Shack) in parallel with the LED. The resistor carries plenty of current to excite the alternator and the LED operates normally, "on" when ignition on and engine not running, "off" when engine starts.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
